Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
A surface represents the geometry associated with a physical part. A surface is a two-dimensional geometric entity that
may be used in automatic mesh generation.
Solids are closed volume of surfaces that can take any shape. Solids are three-dimensional entities that can be used in
automatic tetra and solid meshing.
A face is a single Non-uniform Rational B-Spline (NURBS) and is the smallest area entity. It has a separate underlying
mathematical definition, specified when it was created.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
Create and edit circles and rectangles with the Shapes tool.
Create and Edit Circles
Use the Circles tool to create circles for geometry construction, edit free circles, and create/toggle filled circles (for example, disk surfaces).
Create and Edit Rectangles
Use the Rectangles tool to create rectangles for geometry construction, edit free rectangles, and create/toggle filled rectangles.
