Find and Fill Cavities
Use the Plug tool to find and fill cavities. The Plug tool can also be used to remove protrusions, holes, and complex features.
You can interactively fill cavities using the guide bar or fill all cavities at once.
Plug Tool
An overview of the Plug tool.
Figure 3.
Use the Plug tool to find and fill cavities and holes from a solid.
- Access
- Go to .
Options
- Find cylindrical cavities only
- Find cylindrical cavities only.
- Maximum width
- Maximum width.
- Minimum concavity factor
- Change the factor.
- Merge
- Merge filled solid with input solid by removing shared surfaces.
