Voxel: Connect Tool
An overview of the Voxel: Connect tool.
Use the Voxel: Connect tool to create tetra mesh from closed volumes of shell elements, or from solid or closed surface geometry.
- Access
- Go to .
Options
- Tolerance
- Specifies the search distance. Any nodes of the structure within that tolerance will be attached to the voxel design space. It is typical to use a value that is approximately 75% of the voxel mesh size.
