If desired, define the output using the User-Defined tab (which will allow you to
specify the properties of the output using user subroutines).
From the Result Type drop-down menu, select User
Defined.
Define the user subroutine.
Enter the user subroutine function expression in the in the User expr:
text box.
Activate the Use local file and function name
check box if the use of a local subroutine file is necessary.
Select the subroutine file in the local system by clicking on the
Local File: folder icon .
From the Function Type drop-down menu, select the type of the
subroutine file: DLL/SO,
Python, or MATLAB.
Enter the function name in the Function Name: text box.
MotionView provides REQSUB as the default, which is
the default function used by MotionSolve and
ADAMS.
