Rider plays an important role in two wheeler dynamics. To capture the effects of rider on a vehicle, it is important
to have a good human body multi-body dynamics model.
As the name suggests, it refers to two shock absorbers at the rear end of a
motorcycle. This arrangement allows for a higher spring deflection, as the spring
pick-up at the bottom is closer to the wheel center. Figure 1.
