Set Wizard Paths Dialog
The Set Wizard Path dialog allows you to select directories in which several files are stored.
- Assembly Wizard file
- Task Wizard file
- MDL standard include file
- Wizard library directory
- Report log file
- OK
- Applies the changes and exits the dialog.
- Cancel
- Exits the dialog.
