Running the Current Model
- Check Export MDL snapshot to save a copy of the MDL file in the current state at which the model is being submitted to the solver.
- Check Export MDL animation file to write an .maf file which can be loaded as a model in HyperView to view results with .mrf.
- Click Animate to animate the results in a HyperView window after the solution is completed.
- Click Plot to plot the results in a HyperGraph window after the solution is completed.
