PARAM, ALLFT
Bulk Data Entry Multiple Failure Theory output is activate or not, and all supported failure theory output is calculated for the given model.
Parameter | Values | Description |
ALLFT | <YES,
NO> Defaults:
- PUCK failure is output only if the corresponding MATF material information for PUCK is present.
