PARAM, FIXRBE3
Bulk Data Entry Used to automatically fix invalid RBE3’s.
Parameter | Values | Description |
FIXRBE3 | <YES, NO> | Used to automatically fix
invalid RBE3's, which typically exhibit the following
characteristics.
- For PARAM,FIXRBE3,YES, the fixed RBE3’s are printed in the .out file. It is the responsibility of the user to check these RBE3’s and make sure that the model behavior is not unexpected.
