Process Manager Directory Structure
- My Process
- The process definition files (.pmt and .pmd) will be placed here. This is the base directory for the process.
- controls directory
- Java beans specific to this process in archive format (.jar files) will be placed in this directory.
- help directory
- The help files (in HTML format) associated with each task in the process will be placed here.
- icons directory
- Any icon file (if required) used by the process will be placed here.
- modules directory
- The Tcl modules to be associated with the tasks in the process will be placed here.
- tclincludes directory
- The Tcl helper files for the modules will be located here. The Process Manager Framework will automatically source these files when the process is loaded.
- customlibs directory
- (As the A JRS are not representing the Beans) and place all JARS under this. The JARs will be loaded in JVM by adding these to CLASSPATH variables.
