The Altair GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HyperWorks commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
The Model Identification Tool, known as HyperWorks, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The HyperWorks operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using
the HgTrans GUI or via the HgTrans batch mode.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble
HyperWorks automations with minimal effort and maximum portability.
HyperWorks Verification and Validation Harness (HVVH) is a tool that can be used to verify and validate HyperWorks products. End users can use this tool to quickly evaluate the software quality, performance, reliability,
scalability, and robustness, and to gain more confidence in HyperWorks products.
Uninstall HyperWorks is a tool to launch the HyperWorks uninstallation program. This program contains two options that allow you to either remove the originally installed
files, or remove all the files that resides in the installation directory.
Use the Open dialog to locate and load your session file.
All GUI entries needed as input are loaded.
Note: Each individual option
has a session file. The loaded session file takes you to the respective
options. For example, the session selected in Figure 2 takes you to
the CAD > CAD IO tab.
Save Session
Load an existing session file or manually enter all input fields on a given
tab.
From the menu bar, click File > Save New Session.
The Save New Session dialog is displayed.
In the dialog, save the required session file.
All GUI entries needed as input are saved in the session file.
Each individual tab has a session file. When loaded again, the saved session
file takes you to the respective tab.
Below is an example of the session file,
FEBASICIO.session.
