The Altair GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HyperWorks commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
The Model Identification Tool, known as HyperWorks, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The HyperWorks operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using
the HgTrans GUI or via the HgTrans batch mode.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble
HyperWorks automations with minimal effort and maximum portability.
HyperWorks Verification and Validation Harness (HVVH) is a tool that can be used to verify and validate HyperWorks products. End users can use this tool to quickly evaluate the software quality, performance, reliability,
scalability, and robustness, and to gain more confidence in HyperWorks products.
Uninstall HyperWorks is a tool to launch the HyperWorks uninstallation program. This program contains two options that allow you to either remove the originally installed
files, or remove all the files that resides in the installation directory.
In this tutorial, you will learn how to perform model setup in HyperMesh and identify problems during the interactive
HyperMesh operation.
FE Model Setup - First Use Case
In this step you will perform the FE Model setup using the Model Setup
tab.
From the FE Model tab, select the Model
Setup tab.
From the Solver Type list, select OptiStruct.
From the HW Version list, select 2020.
Click the Modify script/cmf checkbox.
Do not select the Config file or Models option.
Under the Script/cmf files section, click the file browser icon, , or the
add file icon, , to load the Plate.tcl file,
located in ..\tutorials\hvvh\FEModel\ModelSetup.
In the Output directory field, click to
select an output directory.
Click Run.
The model file with the script is imported and a set of operations in
HyperMesh are executed. The status is
displayed under Model Setup info.
If the selected Tcl file is executed correctly and there are no problems with
the HyperMesh operations, the status displays
Pass.
In the Messages window, the run details and the log file
location are displayed.
Click HTML Report to open an HTML report which contains
details of the script executed in HyperMesh.
FE Model Setup - Second Use Case
Setup tab.
Click the Modify script/cmf and Config
file check boxes.
Do not select the Models option.
In the Config file field, click to load
the Model_setup_cfg.txt file, located in
Click Run.
Figure 3.
When you select the config file, the operation is interactive and HyperMesh starts, allowing you to see the model's
interactive operations.
Pass. If there are additional lines at the end of the command files that are
generated compared to the original script, it is highlighted in orange as a
warning.
FE Model Setup - Third Use Case
Setup tab.
From the Current Version list, select 2020.
From the Reference Version list, select 2017.0.
Click the following check boxes: Modify
script/cmf,Config file, and
Ref Version.
Click Run.
The model file with the script is imported and a set of operations in Current
HM Version and Reference HM Version are executed. The status is displayed
Pass. If additional lines are generated at the end of the command files
warning.
Click HTML Report to open an HTML report. The report
contains details of the script executed in HyperMesh.
Setup an FE Model with the Process Manager Template
Setup tab.
Activate the Modify script/cmf and Config
file checkboxes.
Under the Script/cmf files section, click the file browser icon, ,or the
add file icon, , to load the Launch.tcl file,
located in ..\tutorials\hvvh\FEModel\ModelSetup\pmt.
Important: Edit the process template path in
Launch.tcl.
Under the Config file section, click to load
..\tutorials\hvvh\FEModel\ModelSetup\pmt\ModelSetup.txt.
Click Run.
Note: The Config file option should always be ON to execute the Process Manager
template, with quit = 1 in
ModelSetup1.txt. The default of
quit = 0 or no entry continues
without waiting for user input.
Pass. If there are additional lines are generated at the end of the command
file compared to the original script, it is highlighted in orange as a
warning.
Generate Keyword Coverage Summary
From the FE Model tab, select the Keywords
coverage tab.
Figure 4.
From the File Type list, select LS-DYNA.
Under the Input Deck(s) section, click the file browser icon, , or the
add file icon, , to load the following files:.
Click Generate.
From the imported solver decks, supported, unsupported, and partially
supported keywords are generated.
Click the pie chart to view details regarding the published files, as well as
to see details in a document of supported, unsupported, and partially supported
keywords based on the analysis decks.
All individual and combined files are listed in the document.
Figure 5.
Basic Import and Export
Identify any loss of data during solver import and export.
From the FE Model tab, select the Basic
IO tab.
Figure 6.
From the File Type list, select OptiStruct.
Click the Model Checker/Entity count check box.
Use the default Export profile.
Under the Input deck(s) section, click the file browser icon, , or the
..\tutorials\hvvh\FEModel\BasicIO\buckling1.fem
..\tutorials\hvvh\FEModel\BasicIO\car1.fem
Click Import/Export.
Under Step 1, the import and export time and status (pass or fail) of the
reference model file (selected above) are displayed.
The last column displays information on the ASCII difference between the
imported file and the HyperMesh exported file.
If there are no differences, Pass is displayed (otherwise, Fail).
Step 2 displays the import and export time and status (pass or fail) of the
exported model file that is re-imported into HyperMesh (along with the import and export status
and time).
model checker summary of the file in steps 1 and 2. Any loss of data is
identified.
Click Check run.
The original model and the HyperMesh exported
models are run with the Radioss solver. The OUT
file blocks are compared as shown in the status.
Click HTML Report to open an HTML Report.
Figure 7.
Figure 8.
Compare HyperMesh Versions
From the FE Model tab, select the Compare HM
Versions tab.
14.0.0.130.
Under the Input deck(s) section, click the file browser icon, , icon or
the add file icon, , to load the following files:
The first table details the import and export time and status (pass or fail)
of the model file selected in the current version.
The second table details the import and export time and status (pass or fail)
of the model file selected in the reference version.
exported files in the current and reference versions of HyperMesh. If there are no differences, Pass is
displayed (otherwise Fail).
Figure 9.
Special Case: Compare HyperMesh Exported Decks Based on FE
Entities
From the FE Model tab, select the Special
case tab.
Figure 10.
Do not select the IO Merge or Export Merge options.
In the Input file field, click the file browser icon, , or the
add file icon, , to load the following file:
..\FE Model\Special case\bumper_deck.key.
The first table details the import and export times and status (pass or fail)
of the model file in the HyperMesh version
selected.
The file is re-imported and the status is displayed under Re-import
status.
FE entities are compared with the original solver deck. Any changes in data
shows any loss of data, otherwise it is shown to pass.
Figure 11.
Check Interactive Operations in HyperCrash and Compare
Exported Files
From the FE Model tab, select the HC
Session tab.
Figure 12.
From the File type list, select Radioss
v2017.
Click Reference file.
Click the Input File field.
Click the add file icon, , to load the
FOAMD00_v14_0000.rad file, located in
...\tutorials\hvvh\FEModel\HCSession\.
Click the Session File field.
Click to load the Position.xml file,
located in ...\tutorials\hvvh\FEModel\HCSession\.
Click the Reference File field.
Click to load the
FOAM_Dummy_Reference_0000.rad file, located in
...\tutorials\hvvh\FEModel\HCSession\d.
In the Output directory field, click the file browser icon, , to
Click Execute.
The input file is imported into HyperCrash. Using
the session file, a set of interactive operations are executed in HyperCrash and the file is exported.
In the Compare table, the Diff column displays information on the ASCII
difference between this exported file and the current and reference files
selected above. If there are no differences, it is displayed as Pass
(otherwise, Fail).
Figure 13.
Figure 14.
The difference between the exported files is not significant.
HyperCrash Basic Import and Export
From the FE Model tab, select the HC Basic
IO tab.
Figure 15.
From the File Type list, select Radioss
v2017.
From the HW version list, select 2020.
From the Unit System list, select kN-mm-ms-kg.
Click Model checker.
add file icon, , to load the model01_0000.rad
file, located in ..\tutorials\hvvh\FEModel\HCBasic IO\
file.
Under Step 1, the import and export time and status details (pass or fail) of
the reference model file (selected above) are displayed.
imported file and the HyperCrash exported file.
If there are no differences, Pass is displayed, otherwise Fail.
exported model file that is re-imported back into HyperCrash (along with the import and export status
and time).
model checker summary file in steps 1 and 2. Any loss of data is
identified
Click Check run.
Compare HyperCrash Versions
From the FE Model tab, select the Compare HC
versions tab.
Figure 16.
v14.
From the Current version list, select 2020.
14.0.0.130.
Under the Input File section, click the file browser icon, , or the
add file icon, , to load the model01_0000.rad file, located in
..\tutorials\hvvh\FEModel\CompareHCVersions\model01_0000.rad.
fail) of the model file selected in the current version.
The second
table details the import and export time and status (pass or fail) of the
information on the ASCII difference between the exported files in the
current and reference versions of HyperCrash. If
there are no differences, it is displayed as Pass, otherwise Fail.
In the
Messages window, the run details are displayed along
with the log file location.
