Load Step: Output Request: Result File (.fil)
In the Result file (.fil) dialog, define and edit the output requests for the Result file.
Supported keywords are *NODE FILE, *ELEMENT FILE, *CONTACT FILE, and *ENERGY FILE. To open the dialog in the Load Step window, select Result File (.fil) from the tree and an Output block from the table.
Load Step: Output Request: Result File: Define
In the Define tab, enable the Node File, Element File, Contact File, and Energy File tabs, which are used to define the *Node File, *Element File, *Contact File, and *Energy File cards, respectively.
Load Step: Output Request: Result File: Node File
In the Node File tab, define *Node file for the selected Output block.
The following parameters are supported: Nset, Frequency, Last mode, Global, and Mode. Activate/deactivate the checkboxes in the tree on the Node File tab to add/remove identifier keys in the table. The data lines added in this manner have a gray background, indicating they cannot be manually edited. You may also add user-defined identifiers by typing them directly into the table. User-defined data lines appear with a white background, indicating they are editable.
Right-click on the Data lines table to display menu options. The available options are Cut, Copy, Paste, Add row, and Delete row.
Button | Action |
Create/Edit... | Opens the Entity Sets panel in Engineering Solutions. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the node set list. |
Review | Reviews the selected node sets by highlighting them in the Engineering Solutions graphics. Right-click on the Review button to clear the review selections. |
Update | Updates the Engineering Solutions database with the data lines defined in the table and the parameters. |
Load Step: Output Request: Result File: Element File
In the Element File tab, define *ELEMENT FILE for the selected Output block.
The following parameters are supported: Elset, Directions, Mode, Frequency, Position, and Last Mode. Activate/deactivate the check boxes in the tree on the Element File tab to add/remove identifier keys in the table. The data lines added in this manner have a gray background, indicating they cannot be manually edited. You may also add user-defined identifiers by typing them directly into the table. User-defined data lines appear with a white background, indicating they are editable.
Button | Action |
Create/Edit... | Opens the Entity Sets panel in Engineering Solutions. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the element set list. |
Load Step: Output Request: Result File: Contact File
In the Contact File tab, define *CONTACT FILE for the selected Output block.
The following parameters are supported: Nset, Master, Slave, and Frequency. Activate/deactivate the checkboxes in the tree on the Contact File tab to add/remove identifier keys in the table. The data lines added in this manner have a gray background, indicating they cannot be manually edited. You may also add user-defined identifiers, by typing them directly into the table. The user-defined data lines appear with a white background, indicating they are editable.
Button | Action |
Review | Reviews the selected node sets, master surface, or slave surface by highlighting them in the Engineering Solutions graphics. Right-click on the Review button to clear the review selections. |
Load Step: Output Request: Result File: Energy File
In the Energy File tab, define *ENERGY FILE for the selected Output block.
The following parameters are supported: Elset and Frequency.
Button | Action |
Review | Reviews the selected element sets by highlighting them in the Engineering Solutions graphics. Right-click on the Review button to clear the review selections. |
