Advanced Averaging
Advanced averaging means that tensor (or vector) results are transformed into a consistent system and then each component is averaged separately to obtain an average tensor (or vector).
Where, are
tensors transformed to the reference system for corners A2, B1, C3, and D4,
respectively.
The components are extracted and the invariants are computed from this
averaged tensor or vector .
Element Type | Reference System | Projection Rule | Description |
Solid | Global | N/A | All corresponding tensors and vectors are transformed to the global coordinate system and an average tensor/vector is calculated. The components and invariants are obtained from this tensor/vector as explained above. |
User-defined | N/A | Variation ON All corresponding tensors and vectors are transformed to the user-defined coordinate system and an average tensor/vector is calculated. The components and invariants are obtained from this tensor/vector. Variation OFF All corresponding tensors and vectors are transformed to the global coordinate system and an average tensor/vector is calculated. Then, this average tensor/vector is transformed to the user-defined system for components extraction and invariants calculation. |
Shell | Global | ON | The global co-ordinate system is projected to the Nodal Projection plane
(described in the Projection rule) to obtain the Nodal Projection system. All
corresponding tensors/vectors are then transformed to the Nodal projection system
obtained from this tensor/vector. As a result, even if the reference system is the same, the projected systems in participating elements can be different. Simple averaging for components ignores variations in systems. |
OFF | All corresponding tensors and vectors are transformed to the global coordinate system and an average tensor/vector is calculated. The components and invariants are obtained from this tensor/vector. | ||
User-defined | ON | The user-defined co-ordinate system is projected to the Nodal Projection
plane (described in the Projection rule) to obtain the Nodal Projection system.
Variation ON All corresponding tensors/vectors are then transformed to the Nodal projection system and an average tensor/vector is calculated. The components and invariants are obtained from this tensor/vector. Variation OFF All corresponding tensors and vectors are transformed to the global coordinate system and an average tensor/vector is calculated. Then, this average tensor/vector is transformed to the Nodal projection system for components extraction and invariants calculation. |
OFF | Variation ON All corresponding tensors and vectors are transformed to the user-defined coordinate system and an average tensor/vector is calculated. The components and invariants are obtained from this tensor/vector. Variation OFF All corresponding tensors and vectors are transformed to the global coordinate system and an average tensor/vector is calculated. Then, this average tensor/vector is transformed to the user-defined system for components extraction and invariants calculation. |
Valid reference coordinate system: Global and User-defined.
