Do one of the following:
From the Home tools, click the Measure
tool.
Then, from the Measure panel, click Add under the
Measure Groups list.
Right-click in the Results Browser and select .
A new measure group with a
default name is added to the list.Tip: Use the Rename (right-click context
menu) option to rename the new measure group if desired.
