Change the Tensor Color by Value From the View Controls toolbar, click . From the Tensor panel, click the Display tab (located in the middle of the panel). Select Value from the Color by drop-down menu. Applies colors to the tensors based on values and the legend settings. Click the Edit Legend button. Modify the legend values and colors in the Edit Legend dialog. Click Apply to save the settings.
