Change the Vector Color by Value From the View Controls toolbar, click . From the Vector panel, click the Display tab (located in the middle of the panel). Select Value from the Color by drop-down menu. The Edit Legend button becomes enabled in the Legend tab. From the Legend tab, click Edit Legend. Modify the legend values and colors in the Edit Legend dialog.
