HM-4640: Dummy Position
In this tutorial, you will learn the different functionalities available in default to position a dummy in its environment.
The driver seat and environment used in this tutorial are based on the LS-DYNA Toyota Yaris model, provided on the National Crash Analysis Center (NCAC) website.
The LS-DYNA dummy model used in this tutorial is a release version of the THOR-Mod Kit/Metric crash test dummy with SD3 shoulder posted on the NHTSA website.
- H-Point Positioning
- Manual and automatic positioning of dummy limbs
- Saving/Retrieving dummy positions
- Linking a dummy to a seat mechanism
Load the User Profile
In this step you will open HyperMesh along with the LS-DYNA user profile.
- Start HyperMesh Desktop.
- In the User Profile dialog, set the user profile to LS-DYNA, Keyword971_R8.0.
Open the Model File
In this step you will open the model file, dummy_positioner.hm.
- From the menu bar, click .
- In the Open Model dialog, navigate to your working directory and open the file, dummy_positioner.hm.
Position the Dummy
In this step you will position the dummy to its H-point location.
Position the Limbs
In this step you will manually position the dummy limbs.
Position the Hands
In this step, you will automatically position the hands.
Save and Retrieve Dummy Positions
In this step, you will save and retrieve dummy positions.
Link to a Seat Mechanism
In this step you will link a dummy to a seat mechanism.
By default you can link a dummy to a defined seat mechanism. In this way, when the seat is moved to another position, the dummy position will be automatically updated.
