HM-4650: Seat Deformer with LS-DYNA Pre-Simulation
In this tutorial you will learn how to setup a LS-DYNA model to simulate the seat deformation under the dummy.
The driver seat and environment used in this tutorial are based on the LS-DYNA Toyota Yaris model, provided on the National Crash Analysis Center (NCAC) website.
The LS-DYNA dummy model used in this tutorial is a release version of the THOR-Mod Kit/Metric crash test dummy with SD3 shoulder posted on the NHTSA website.
Load the User Profile
In this step you will open the LS-DYNA user profile.
- Start HyperMesh Desktop.
- In the User Profile dialog, set the user profile to LS-DYNA, Keyword971_R8.0.
Open the Model File
In this step you will open the model file, seat_deformer.hm.
- From the menu bar, click .
- In the Open Model dialog, navigate to your working directory and open the file, seat_deformer.hm
Position the Dummy
In this step you will position the dummy to its H-Point location.
Generate the Seat Deformer Model
In this step you will generate the seat deformer model for the LS-DYNA Simulation.
Review Seat Deformer Simulation Results
In this step you will review the seat deformer simulation results and update the initial model.
Check also that LS-DYNA has written out the dynain file, which contains the new coordinates of the seat nodes at the end of the simulation, as well as the *INITIAL_STRESS cards for the different type of elements present in the seat model (beam/shell/solid).
To update the initial model with the simulation results, proceed as follows:
