Use the Editor to create and edit template files, parameterize ASCII files, create variables or shape templates, recognize
and edit Templex statements in files, execute parameterized files, and perform advanced editing.
An input variable is a system parameter that influences the system performance in the chosen output response. It is
an object that is varied by the study based on certain rules.
By default, all input variables imported or manually added to your study are made active. Make an input variable inactive
so that it is no longer an independent variable.
Reduce the number of independent variables and/or of different models in multi-model studies in order to have synchronized
design updates between models by linking input variables to each other.
Once the study Setup is complete, an unlimited combination of approaches can be added to a study. A study approach
is a specific set of steps taken to study the mathematical model of a design.
