Allows rotation of the model by manipulating a virtual sphere.
Moves the selected location to the center of the graphics area.
Allows you to select a region to zoom into.
Zooms into the dimensions of the curve in the 3-D plot.
Changes the size of the 3D plot to fit into the entire window.
Finds the orientation of the plot.
Finds the ortho (volume) of the 3D plot.
Finds the angle of rotation.
Finds the view matrix for the 3D plot.
Performs a dynamic pan of the model.
Rotates the model clockwise about an axis perpendicular to the screen.
Rotates the model counter-clockwise about an axis perpendicular to the screen.
Rotates the model down about an axis oriented horizontally across the screen.
Rotates the model left about an axis oriented vertically across the screen.
Rotates the model right about an axis oriented vertically across the screen.
Rotates the model up about an axis oriented horizontally across the screen.
Rotates the 3D plot along the x axis.
Rotates the 3D plot along the y axis.
Rotates the 3D plot along the z axis.
Performs a dynamic zoom of the model.
Sets the orientation of the plot.
Sets the ortho of the 3D plot.
Sets the rotation angle.
Moves the position of the 3D plot within the window.
Allows rotation of the model by performing a dynamic rotation.
Zooms in or out of the plot based on the factor given.
ON THIS PAGE
ON THIS PAGE
