HM_strlwr()
Converts the characters in a string to lower case.
char * HM_strlwr(char * string);
HyperMesh hmlib Function
- string
- A pointer to a string.
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Copies a string of absolute length.
Checks the characters in a string for those considered valid for a double field.
Checks the characters in a string for those considered valid for an integer field.
Counts the number of occurrences of a character in a string.
Deletes a string of characters from a string.
Performs a string compare, ignoring upper and lower case.
Inserts a string into another string.
Inserts a character into a string.
Replaces a string within a string.
Removes end of line spaces.
Removes leading and trailing spaces from a string.
Converts the characters in a string to upper case.
Extracts the integer value from a string.
None.
