open
Open files.
open entity argument ?argument? ?argument? ?argument? ?argument?
Use HWC commands in the Tcl Console.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Marks entities on the active model.
Open files.
Open model and result files.
Execute an HWC script file.
Open a session file and set parameters.
Import a session using default parameters.
Result loading.
Result loading.
Save session content.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Tracking system commands.
View manipulation.
Open files.
ON THIS PAGE
Open files.
ON THIS PAGE
