ardi::frwk
ardi::frwk::addcustompackage args
Registers Tcl package to load containing custom module.
-directory
directory that contains Tcl package.
default value: ""
-packagename
name of Tcl pacage.
k
default value: ""
Returns
1 for ok
tcl-error in case of error public method addcustompackage { args }
ardi::frwk::addcustompath args
Registers additional search path(s) to locate custom modules.
-directory
one or a list of paths separated by blank.
default value: ""
Returns
1 for ok
ardi::frwk::appendtemplate args
Appends the specified report template to existing report template.
-file
filename of report template.
default value: ""
Returns
1 for ok
ardi::frwk::execute args
Executes the current report template.
-id
id of the items to be executed.
default value: "root" all items in the report will be executed
Returns
1 for ok
ardi::frwk::export args
Exports the MS-Office report based on current report template.
-file
filename of MS-Office report including extension.
default value: ""
Returns
1 for ok
ardi::frwk::getmasterdocument
Queries the current MS-office master template file based on current report format (Word, ppt).
Returns
the current MS-Office master template file.
ardi::frwk::getreporttype
Queries the MS-office report type.
Returns
the current MS-Office report type (Word, ppt).
ardi::frwk::getworkdir
Queries the current work directory.
Returns
ardi::frwk::loadtemplate args
Loads the specified report template.
-file
default value: ""
-filelist
Optional. List of filenames as seen on "Report Template" dialog or as passed or as used in the order of running HyperWorks in batch mode. See HyperWorks documentation "barchmode" parameter "-tplParams"
Returns
1 for ok
ardi::frwk::newreport args
Creates new report template.
-type
type of report (Word, ppt).
default value: ""
Returns
1 for ok
ardi::frwk::quit
Quits ARD.
-mode
values: interactive (interactive with GUI), mute (engine only, no GUI).
default value: ""
Returns
1 for ok
ardi::frwk::registertype
Register a new type relating to an editor.
-type
unique one-word, all lowercase identifier for the new type. This is the identifier you will need to specify in the module's XML file.
-class
ITcl class that contains the editor code. Make sure to use proper namespace for your custom editor to avoid naming clashes.
Returns
1 for ok
ardi::frwk::savetemplate args
Saves the current report template.
-file
default value: ""
Returns
1 for ok
ardi::frwk::setmasterdocument args
Sets the MS-Office master template based on current report format (Word, ppt).
-file
default value: ""
Returns
1 for ok
ardi::frwk::setworkdir args
Sets the work direcgtory to specified path.
-directory
path of work directory.
default value: ""
Returns
1 for ok
ardi::frwk::start args
Starts ARD in desired mode.
-mode
default: ""
Returns
1 for ok
ardi::frwk::templateloadpostcommand args
Specify the callback to be called after a new report template got loaded.
-command
command, Tcl procedure or ITcl method to be called.
default value: ""
Returns
1 for ok
ardi::frwk::templateloadprecommand args
Specify the callback to be called before a new report template is being loaded.
-command
default value: ""
Returns
1 for ok
