reldisp
The relative displacement (reldisp) math function allows you to transform vector results from time history or animation result files according to a coordinate system defined by three nodes from the same result file.
reldisp(x_vector, dummy_param, node_ID_origin, node_ID_xdir, node_ID_xyplane, node_ID_trans, transformed_value, coord_system)
reldisp(p1w3c1.x,0,198,252,251,2968,"x","OXY"
Argument
- x_vector
- Independent vector (x vector) which must be the time vector of the type file. This must be an absolute math reference like "p1w1c1.x". If a non-supported file type is provided, an error is displayed in the message log. The subcase is read from the subcase of the time vector referred to by this argument.
- dummy_param
- Dummy parameter for future use; set to 0.
Arguments 3-5 define the IDs of the coordinate systems.
- node_ID_origin
- The node for the coordinate system's origin.
- node_ID_xdir
- The node ID for the x direction.
- node_ID_xyplane
- The node ID for the xy plane.
- node_ID_trans
- The node ID for which the results will be transformed.
- transformed_value
- Defines which value is returned for the transformed node.
- coord_system
- Defines the coordinate system according to HyperView (default = "OXY"). Possible values are "OXY", "OYZ" or "OZX".
This allows you to see the relative displacements in the higher sampling rate normally provided by time history results.
The function supports PAM-CRASH (*.thp, *.dsy), LS-DYNA (*.d3plot, *.nodout, *.binout), and Radioss (*.thp) files.
