LS-DYNA to Radioss Conversion Mapping
Airbag
LS-DYNA | Radioss |
*AIRBAG_SIMPLE_AIRBAG_MODEL | /MONVOL/AIRBAG1 |
*AIRBAG_SIMPLE_PRESSURE_VOLUME | /MONVOL/PRES |
Boundary
LS-DYNA | Radioss |
*BOUNDARY_PRESCRIBED_MOTION | IMPASS, IMPVEL or IMPDISP |
Constrained Definitions
LS-DYNA | Radioss |
*CONSTRAINED_Extra_NODES_SET | /RBODY,/GRNOD/GRNOD,/GRNOD/PART |
*CONSTRAINED_JOINT_REVOLUTE | /SPRING,/PROP/KJOINT2/ property type 2 |
*CONSTRAINED_JOINT_SPHERICAL | /SPRING,/PROP/KJOINT2/ property type 1 |
*CONSTRAINED_JOINT_CYLINDRICAL | /SPRING,/PROP/KJOINT2/ property type 3 |
*CONSTRAINED_JOINT_LOCKING | /PROP/KJOINT2/property type 8 |
*CONSTRAINED_JOINT_TRANSLATIONAL | SPRING elements, /PROP/KJOINT2/ property type6 |
*CONSTRAINED_JOINT_STIFFNESS_GENERALIZED | /SPRING |
*CONSTRAINED_RIGID_BODY | /RBODY |
Control Cards
LS-DYNA | Radioss |
*CONTROL_ADAPTIVE | ADMESH_GLOBAL, ADMESH_SET |
Contact
LS-DYNA | Radioss |
*SECTION_BEAM ELFORM=1 | /PROP/TYPE18 |
*CONTACT_TIED_SHELL_EDGE_TO_SURFACE_ID | /INTER/TYPE2,/INTER/TYPE10 |
*CONTACT_TIED_NODES_TO_SURFACE | /INTER/TYPE2,/INTER/TYPE10 |
*CONTACT_AUTOMATIC_GENERAL | /INTER/TYPE7,/INTER/TYPE10 |
Contact Interfaces
LS-DYNA | Radioss |
*CONTACT_AUTOMATIC_GENERAL | INTER/TYPE7 |
*CONTACT_AUTOMATIC_GENERAL_INTERIOR | INTER/TYPE7 |
*CONTACT_AUTOMATIC_NODES_TO_SURFACE | INTER/TYPE7 |
*CONTACT_AUTOMATIC_ONE_WAY_SURFACE_TO_SURFACE | INTER/TYPE7 |
*CONTACT_AUTOMATIC_SINGLE_SURFACE | INTER/TYPE7 |
*CONTACT_AUTOMATIC_SURFACE_TO_SURFACE | INTER/TYPE7 |
*CONTACT_INTERIOR | INTER/TYPE7 |
*CONTACT_SPOTWELD | /TYPE2 |
Components
LS-DYNA | Radioss |
*DAMPING_PARTS_OPTIONS | PART |
*PART_OPTIONS | PART |
*INCLUDE_STAMPED_PART | PART |
Curves
LS-DYNA | Radioss |
*DEFINE_CURVE | FUNCT |
Database
LS-DYNA | Radioss |
*DATABASE_EXTENT_BINARY | ANIM/SHELL/TENS/STRESS/UPPER ANIM/SHELL/TENS/STRESS/MEMB ANIM/BRICK/TENS/STRESS ANIM/ELEM/EPSP ANIM/SHELL/EPSP/UPPER ANIM/SHELL/SPEP/LOWER |
*DATABASE_HISTORY | /TH/SHEL,/TH/SH3N,/TH/BRIC cards |
*DATABASE_HISTORY_NODE | /TH/NODE |
*DATABASE_BINARY_D3PLOT | /TFILE/1 |
*DATABASE_OPTION | /TFILE/1 |
*DATABASE_HISTORY_NODE_SET_LOCAL | /TH/NODE |
*DATABASE_CROSS_SECTION_PLANE | /SECT |
*DATABASE_CROSS_SECTION_PLANE_OPTION (CIRCLE) | /SECT/PLANE |
Define
LS-DYNA | Radioss |
*DEFINE_TABLE | /TABLE |
*DEFINE_CURVE | /FUNCT |
Elements
LS-DYNA | Radioss |
*ELEMENT_SHELL | SHELL, SH3N |
*ELEMENT_SOLID | BRICK, TETRA44 |
*ELEMENT_MASS | ADMAS/TYPE5 |
*ELEMENT MASS PART | /ADMAS/TYPE5 |
*ELEMENT MASS SET | /ADMAS/TYPE6 |
*ELEMENT_BEAM | BEAM |
*ELEMENT_BEAM_ORIENTATION | /BEAM,/SPRING |
*ELEMENT_DISCRETE | SPRING2N |
*ELEMENT_SEATBELT_ACCELEROMETER | ACCEL,/SKEW/MOV,/ADMAS |
Loads
LS-DYNA | Radioss |
*BOUNDARYSPC_NODE | /BCS |
*BOUNDARY_SPC_NODE/SET | BCS |
*LOAD_BODY | /GRAV |
*LOAD_NODE_POINT/SET | CLOAD |
*INITIAL VELOCITY_BODY | /INVEL/TRA, /INVEL/ROT |
*INITIAL_VELOCITY_NODE/GENERATION/ RIGID BODY | INIVEL |
Materials
LS-DYNA | Radioss |
*MAT_ADD_EROSION | /FAIL/TAB1 and /FAIL/TENSSTRAIN |
*MAT_ARUP_ADHESIVE/MAT_169 | /FAIL/CONNECT, /PROP/CONNECT |
*MAT_CABLE_DISCRETE_BEAM/LAW_071 | /SPRING, property /PROP/SPRING |
*MAT_COHESIVE_MIXED_MODE_ELASTOPLASTIC_RATE/MAT_240 | /MAT/LAW59, /FAIL/CONNECT and /PROP/CONNECT |
*MAT_COMPOSITE_DAMAGE/MAT_022 | /MAT/LAW25 |
*MAT_ELASTIC | M1_ELASTIC |
*MAT_ELASTIC/MAT_001 | /MAT/LAW01,/MAT/LAW02 |
*MAT_GENERAL_VISCOELASTIC | /MAT/LAW42 |
*MAT_LINEAR_ELASTIC_DISCRETE_BEAM/LAW_066 | /SPRING,/PROP/SPR_BEAM |
*MAT_PLASTIC_KINEMATIC | M36_PLASTIC_TAB |
*MAT_PLASTIC_KINEMATIC | /MAT/LAW44 |
*MAT_NULL | M0_VOID |
*MAT_ORTHOTROPIC_ELASTIC/MAT_002 | /MAT/FABRI |
*MAT_PLASTICITY_WITH_DAMAGE | LAW88 for rubber and LAW70 for foam |
*MAT_PLASTIC_KINEMATIC_OPTION/MAT_003 | /MAT/LAW44 and /MAT/LAW2 |
*MAT_RIGID | M1_ELASTIC (nodes of material defined as /RBODY) |
*MAT_PIECEWISE_LINEAR_PLASTICITY | M36_PLAS_TAB |
*MAT_SIMPLIFIED_JOHNSON_COOK | M2_PLAS_JOHNS_ZERIL |
*MAT_BLATZ_-KO_RUBBER | M42_OGDEN |
*MAT_SPRING_NONLINEAR_ELASTIC | P13_SPR_BEAM |
*MAT_SPOTWELD_TITLE | P13_SPR_BEAM |
*MAT_SPRING_ELASTIC | /PROP/TYPE13 |
*MAT_SEATBELT | /PROP/SPRING |
*MAT_SEATBELT/MAT_B01 | /PROP/SPRING(TYPE4),/PROP/SPR_PUL(TYPE12) |
*MAT_MOONEY_RIVLIN_RUBBER | /M42_OGDEN /M69 |
*MAT_LOW_DENSITY_FOAM | /MAT/LAW38 |
*MAT_SOLID/TYPE45 | /MAT/LAW70 |
*MAT_FABRIC/MAT_034 | /MAT/FABRI |
MAT_NONLINEAR_ELASTIC_DISCRETE_BEAM_TITLE | /SPRING,/PROP/SPR_BEAM |
MAT_VISCOELASTIC_OPTION/MAT_006 | MAT/LAW42 |
MAT_SPRING_GENERAL_NONLINEAR/MAT_S06 | /PROP/SPR_BEAM |
*MAT_DAMPER_VISCOUS | /SPRING,/PROP/SPR_BEAM |
*MAT_SOIL_AND_FOAM_FAILURE/MAT_014 | /MAT/LAW21 |
*MAT100(spotweld) | /PROP/TYPE13 |
*MAT119 MAT_GENERAL_NONLINEAR_6DOF_DISCRETE_BEAM_TITLE | /PROP/TYPE13 |
Properties
LS-DYNA | Radioss |
*SECTION_BEAM | P3_BEAM |
*SECTION_DISCRETE | P4_SPRING |
*SECTION_SHELL | P1_SHELL |
*SECTION_SOLID | P14_SOLID |
Rigid Walls
LS-DYNA | Radioss |
*RIGIDWALL_GEOMETRIC_FLAT_OPTIONS | RWALL |
*RIGIDWAL GEOMETRIC,FLAT | /RWALL/PARAL |
*RIGIDWAL GEOMETRIC,CYLINDER | /RWALL/CYL |
*RIGIDWAL GEOMETRIC,PRISM | /RWALL/PARAL |
*RIGIDWAL GEOMETRIC,SPHERE | /RWALL/SPHER |
*RIGIDWALL_PLANAR_OPTIONS | RWALL |
Section
LS-DYNA | Radioss |
Sets
LS-DYNA | Radioss |
*SET_NODE_ADD | /GRNOD/NODE |
*SET_NODE_ADD_ADVANCED | /GRNOD/GRNOD |
*SET_NODE_LIST | /GRNOD/GRNOD |
*SET_NODE_GENERAL | /GRNOD/GRNOD |
*SET_NODE_LIST_GENERATE | /GRNOD/GRNOD |
Systems
LS-DYNA | Radioss |
*DEFINE_COORDINATE_NODES | SKEW/MOVE/ |
*DEFINE_COORDINATE_SYSTEM | SKEW/FIXED |
Time History Definitions
LS-DYNA | Radioss |
*DATABASE_HISTORY_BEAM | TH/BEAM |
*DATABASE_HISTORY_NODE | TH/NODE |
*DATABASE_HISTORY_SHELL | TH/SHEL |
*DATABASE_HISTORY_SOLID | TH/BRIC |
*DATABASE_HISTORY_TSHELL | TH/THSH |
*DATABASE_EXTENT_BINARY | /ANIM/SHELL/TENS/STRESS/UPPER |
*DATABASE OPTION | /TFILE/1 |
