Solver-Specific Import Options
Solver-specific options used to determine how FE models are imported.
Abaqus
Generic material
Import a model in the generic material mode.
Expand load on sets
Expand all loads on sets to individual nodes/elements.
Expand sets defined by range
Import all sets with the GENERATE parameter as regular sets.
Tip: This is useful when node/element IDs are renumbered during import.
Retain existing ID's
Retain any pre-existing entity IDs during import.
Import Elset from components
When importing an input file, create an element set with the same name as the component.
Organize orphan entities
Organize orphan entities into separate collectors.
When selected, system collectors defined via HMNAME will be honored, and systems organization into particular system collectors based on their position in the deck will be honored.
An orphaned system is a system in a master or include file that exists without a HMNAME system collector in the same include file. Upon import, orphaned systems are organized into auto-generated system collectors that reside on the same include files as the orphaned systems. This solver option controls how the orphaned systems are organized into the auto-generated system collector(s). When this checkbox is cleared (default), a single system collector is created and all orphaned systems are organized into that single system collector. When this checkbox is selected, separate system collectors are created for each orphaned system.
If a property is assigned to the component, then the ID will be stored in the component. In case of indirect assignment the ID will be stored in the property, and in case of another entity the ID will be taken from the corresponding entity.
Resolve NMAP
Imported files containing node mapping are converted to node mapping using coordinates.
ANSYS
Convert contact elements
Converts contact elements to surfaces.
H3D
Import as Plotel Elements
LS-DYNA
Include files
Create includes assemblies
Automatically create assemblies for each include.
LS-DYNA
Read *INITIAL_STRESS_SHELL / *INITIAL_STRAIN_SHELL
Read the *INITIAL_STRESS_SHELL and *INITIAL_STRAIN_SHELL keywords from the solver deck before importing in HyperWorks. By default, both of these checkboxes are selected, which results in HyperWorks automatically reading the keywords. If you clear these checkboxes, then the data from the *INITIAL_STRESS_SHELL and *INITIAL_STRAIN_SHELL keywords will be exported to a .hmx file.
Use HyperMesh names
Use HyperMesh names (if present) in the solver deck as a comment and name in the LS-DYNA keyword.
Skip *INCLUDE_STAMP files
Skip the include file upon import.
ANSA Comments
Parse ANSA comments from solver decks.
ConstrainedExtraNodes_PID_NID
Associate the keywords *CONSTRAINED_EXTRA_NODE_SET with the name Xtranodes_PID_NID; where PID is the ID of the *PART keyword and NID is the ID of the Node set ID referenced in this keyword.
Write maximum ID's per include
Assign a max ID per Include file instead of assigning a global max ID to elements and properties that do not have solver IDs.
Check unsupported fields/lines
Display a warning message if unsupported fields\lines are found in the deck.
Skip Hyperbeam messages
Skip HyperBeam entity related errors, warnings and information messages.
Read HM Assembly as SET_PART_TREE
Read HM Assembly as SET_PART_TREE.
Moldflow
MPI
Import *.udm files for MPI selected as UDM in the pop-up window.
HyperMesh
Load/save .hm file.
Nastran (MSC) and Nastran (NX)
Delete duplicate
Nodes
Delete duplicate node IDs on import; only the final imported node of a given ID will be retained.
Systems
Delete duplicate systems IDs on import; only the final imported systems of a given ID will be retained.
Tolerance
Delete duplicate tolerance IDs on import.
Read comments
Nastran nodes/elements
Import comment lines on nodes and elements.
ANSA
Read ANSA comments.
FEMAP
Read FEMAP Comments.
Restriction: Only available for Nastran (NX).
Patran
Read Patran comments.
Create SET's based on Patran Group
Create SET's based on Patran Group in deck.
Materials Metadata
Read materials metadata comments.
Organize when missing comments
Use element to property ratio
Defines how imported elements are organized into components. When importing an FE model and the HyperMesh Comments option is selected but no HyperMesh comment cards exist, Nastran users can specify a ratio to be considered when importing HyperMesh entities. On import, HyperWorks will calculate the ratio of the number of elements to the number of properties:
  • If the calculated ratio is less than the specified ratio, all the elements are put into one component.
  • If the calculated ratio is greater than the specified ratio, one component is created for each property.
Ratio
Specify a ratio to be considered when importing HyperMesh entities.
Systems, vectors, beamsects
Organize orphan systems, vectors, beamsects into separate collectors.
Elements
Organize elements in the absence of HyperMesh comments.
Constraints
Convert SPC1 to SPC
Imports SPC1 format as SPC format.
Sets
Expand formula sets on import
Expand formula sets on import.
OptiStruct
Delete duplicates
Nodes
Systems
Read comments
ANSA Comments
Read ANSA comments.
PATRAN
Materials Metadata
Defines how imported elements are organized into components. When importing an FE model and the HyperMesh Comments option is selected but no HyperMesh comment cards exist, OptiStruct users can specify a ratio to be considered when importing HyperMesh entities. On import, HyperWorks will calculate the ratio of the number of elements to the number of properties:
Ratio
Elements
Sets
PAM-CRASH
Radioss
Organize rigid bodies
Organize rigid bodies into a separate collector during import.
Read engine file
Read the Radioss engine cards if an engine file (_0001.rad) is available with the imported input deck.
Read initial shell data
Read and import Radioss initial state cards of 2D elements.
Read initial brick data
Read and import Radioss initial state cards of 3D elements.
Read Optimization file
Read optientities from the corresponding *.radopt file.
