Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
The results post-processing workflow is now embedded in HyperMesh, and you can seamlessly process native results (*.xdb, *.op2) in HyperMesh. The File Loader is used to generate the new results entity.
The MinMax/Ranking/Envelope tool is an extension of the Results Query tool, and allows you to perform additional operations
on data and get dedicated reporting.
The File Loader allows you to import results from native load cases, in the HyperMesh data base, as well as via Load Combination file, to create derived load cases in the form of linear super-position
and/or envelope. Use the Derived Load cases tool for the creation of these derived load cases.
Enables exploring the element force and moment results (internal loads) from solver result files (grid point forces)
for further component sizing/optimization tasks and also for component certification/margin calculation.
In Nastran, the F06 file contains information related either to the diagnostic of the model, analysis check up and results.
This tool enables you to parse a defined number of information blocks and store them as a HyperMesh table entity with a given name.
