NX Reader
NX import is available through two different readers: UGOpen native reader and a third-party non-native reader.
View new features for HyperWorks 2020.
Create a new file.
Open a file.
Import an existing file to the current session.
Entity management settings defined when importing .hm models.
Learn about the CAD readers supported by HyperWorks and the options available for importing CAD geometry data.
CAD readers supported by HyperWorks.
Use the CATIA Composites Link option to import drape data. This method is separate from the CATIA reader, where drape data is not imported.
The FiberSim reader is supported for Nastran and OptiStruct user profiles.
The NX reader utilizes the UGOpen library to read files from NX.
The NX Third Party reader does not need a valid NX installation or license to access these libraries.
CAD readers provide options for processing data during import.
Each reader reads the CAD file and sends the geometry information to HyperWorks. When a CAD file is read, a .msg file is created (or appended to) in the current working directory.
Learn about possible difficulties you may encounter during CAD import.
The metadata names generated by the CAD readers are composed of a general prefix followed by a metadata specific name.
The prefix is specified using the @MetadataPrefix
option in each _reader.ini file.
Import FE models for supported solver interfaces.
Options used when importing a bill of materials file.
Learn about importing connector files.
Options used when importing data via a custom import reader.
Load a different solver interface in HyperWorks.
Playback commands, run scripts, or load a custom solver template to automate your workflow.
Save all of the data in your current session.
Export FE data in your current session.
Take a screen capture of your model and save it to your working directory.
File formats supported by HyperWorks.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
ON THIS PAGE
ON THIS PAGE
