Automatically Fix 2D Element Quality
Use the Auto Quality tool to automatically correct element quality.
![](../../../images/helpAnimationAutoQuality.gif)
Auto Quality Tool
An overview of the Auto Quality tool.
![](../../../images/icons/icon_auto_quality.png)
Figure 3.
- Access
- Go to .
Options
- Edit parameters
- Edit the parameter file via the Parameter Editor. Use the following table to set options:
- Edit criteria
- Edit the criteria file via the Criteria Editor.
- Consider affected elements only
- Only correct elements that are failing the criteria checks, including an optional number of adjacent layers.
- Use adjacent element layers
- Allow the use of adjacent element layers in correction.
- Number of layers
- Change the number of adjacent element layers to use.
- Remesh elements failing QI
- Allows correcting quality by locally remeshing failed elements.
- Reduce tria elements
- Allows local remeshing around tria elements.
