Create and Edit Assigned Entities
Create, edit, and assign new entities to an existing entity or group of entities in the Entity Editor.
Create and Assign a New Entity
To create and assign a new entity to an existing entity or a group of entities:
Edit an Assigned Entity
To edit an entity that is assigned to an existing entity or a group of entities:
- Expand the plus sign () next to an entity assignment field.
- In the embedded Entity Editor, modify the entity data.
- When you are finished making changes, click the minus sign () to collapse the editor.
