Create and Edit Parameters
In the LS-DYNA, OptiStruct, and Radioss user profiles, certain entities can be defined with parameters in the Entity Editor.
Create and Assign a New Parameter
Edit a Parameter
- Right-click on a parameter assignment field and select Edit Parameter from the context menu.
- In the Edit Parameter dialog, modify the parameter's data.
- When you are finished making changes, click Close.
