Tcl Console
The Tcl Console enables you to enter and execute Tcl/Tk commands instead of using the user interface.
The Tcl Console can be turned on or off from the View menu. By default, the Tcl Console opens at the bottom of the application. If a panel and/or the Message Log is also open, the Tcl Console opens as a separate tab.
For more information on commands and scripts, see the HyperMesh Reference Guide.
