Creating Models Using the Assembly and Attachment Wizards
Figure 1. Model Menu
The Assembly Wizard Dialog dialog guides you through the assembly process, ensuring that your selections are compatible. Once you have made your selections, the assembly wizard retrieves the systems from the libraries and connects them in a hierarchical structure.
The attachments specified during the assembly process can be modified using the Attachment Wizard. See the Attachment Wizard Dialog topic for additional information.
After a model is assembled, you can edit model properties using the entity panels. Entity panels are accessed from the Model menu, the toolbars, or by selecting entities from the Project Browser.
