Responses
The Responses step of the wizard allows you to add Response Variables (RVs) to an optimization study.
Response Variables are metrics that characterize system behavior. Each RV is a number that is computed from the system states and the design variables. You create responses by selecting them from a built-in library of response types.
Once added, RVs can be quickly modified or even removed.
