RMOD-K Tire Modeling
Supported Tire Models
- Rigid Belt Model (RFNRB)
- Flexible Belt Model (DMRB)
Available PDF Manuals
- Rigid belt Model (RFNRB)-Detailed manual
- Flexible Belt Model- Detailed manual
Available Online Help
- Installation instructions for the software
- Online help for the two tire models (Rigid Belt and Flexible Belt)
- Documentation for the road surface model
- Documentation describing the tire parameter fitting tool
- Papers describing the tire fitting process
Available RMOD-K Utilities
A variety of utility programs are available to use with RMOD-K. These utilities include: routines that build and correlate the tire model to measured data, a utility that will generate both a parameterized and a measured surface road model, and a utility to view the tire simulation after the model has been run.
Creating Tire Models
- General Tire Information (size, inflation pressure)
- Tire Topology Data
- Tire Force and Moment Measurements
- Tire Cleat Force Measurements
- Modal Information about the Tire
- Miscellaneous Additional Data
Road Surface Models
- Parametric Object Model - The parametric object model road describes the initial road surface and then allows you to describe a series of parametric objects on the road. Parametric objects include a spherical calotte, a cuboid with an optional chamfer, a triangle, and a cylinder.
- Scanned Road Surface - A point cloud , a wavefront file, and a variety of other files can be used to generate road surface models from measured data. Road surfaces can be measured using a road profilometer.
Click on the links below to learn more about the implementation of RMOD-K Tire in MotionView and MotionSolve:
