udfGetNbcAuxCrd()
Return the nodal coordinates for the nodal boundary condition at the auxiliary nodes.
auxCrd = udfGetNbcAuxCrd( udfHd ) ;
AcuSolve User-Defined Nodal Boundary Condition
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
auxCrd (Real*)
Pointer to three dimensional real array of nodal coordinates at the auxiliary nodes. The first (fastest) dimension of the array is the number of nodes, nItems, the second dimension is the number of auxiliary nodes, nAuxs, and the third (slowest) dimension is three, for the x, y and z coordinates. If nAuxs is one, then the array may be treated as two dimensional.
This routine returns the nodal coordinates at the auxiliary nodes. If mesh displacement is active, the returned coordinates are for the current (deformed) configuration. For example,
Real* auxCrd ;
Real x0, y0, z0, x1, y1, z1, x2, y2, z2;
Integer node, nAuxs=3 ;
udfCheckNbcNumAuxs( udfHd, nAuxs ) ;
for ( node = 0 ; node < nItems ; node++ ) {
  x0 = auxCrd[nItems*(0*nAuxs+0)+node] ;
  y0 = auxCrd[nItems*(3*nAuxs+0)+node] ;
  z0 = auxCrd[nItems*(6*nAuxs+0)+node] ;
  x1 = auxCrd[nItems*(0*nAuxs+1)+node] ;
  y1 = auxCrd[nItems*(3*nAuxs+1)+node] ;
  z1 = auxCrd[nItems*(6*nAuxs+1)+node] ;
  x2 = auxCrd[nItems*(0*nAuxs+2)+node] ;
  y2 = auxCrd[nItems*(3*nAuxs+2)+node] ;
  z2 = auxCrd[nItems*(6*nAuxs+2)+node] ;
  • This routine expects a valid udfHd.
  • This routine may only be called within a Nodal Boundary Condition user function.
  • The corresponding command must have a valid auxiliary_nodes parameter.
