udfGetNbcIds()
Return the nodal boundary condition user node numbers.
nodeIds = udfGetNbcIds( udfHd ) ;
AcuSolve User-Defined Nodal Boundary Condition
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- nodeIds (Integer*)
- Pointer to one dimensional integer array of user node numbers. This array has a dimension of number of nodes, nItems.
Integer* nodeIds ;
Integer usrNode, node ;
for ( node = 0 ; node < nItems ; node++ ) {
usrNode = nodeIds[node] ;
- This routine expects a valid udfHd.
- This routine may only be called within an Nodal Boundary Condition user function.
