The Compare HG Versions - Template-Session tab performs time history comparison. From
this tab, you can perform the curve super positioning of the current and reference version
result files and plot the difference in curves.
Click the Result tab then the Compare HG
Versions - Template-Session tab.
Select the current and reference solver
version.
Choose between a PowerPoint or
HTML report of the result value comparison.
Load the session or template file.
Select an output directory.
Click Apply to extract information from the data
file.
Select plot names extracted from the input file.
Tip:
- Activate Plot only failed to plot only failed
graphs.
- Activate Visible Only to plot only visible
graphs.
Click Apply.
The Compare result section displays the current file
and the corresponding reference file. Click Report to
display the diff report detailing the differences between files.
Tip:
- Click Messages to view any
error messages.
- Click Html
Report to generate an HTML report of your
session information for any number of files run through the
process.
