Kernel Parameters
The spline function used to interpolate quantities and derivatives is called a “kernel” in SPH. To define the kernel accordingly to the initial particle configuration the spacing needs to be set here.
kernel
dx 0.1
- dx
- The initial particle spacing. This value is mandatory. Verify it is in agreement with the geometry input file. For example the particles were created with the same initial spacing.
