Post-Processing
nFX[c] post-processed data is often faster to load, easier to represent and easier to understand, especially when looking at the time averaged results.
It is strongely encouraged to take advantage of the nFX[c] when post-processing.
- Use Volumetric Rendering is used in ParaView, after importing nFX[c] data format (.vti), which is the preferred option as it allows for nuanced visualization and provides very effective information and can easily be manipulated for further insights.
- Use particles themselves and reduce their opacity (set it to 0.3 or 0.2).
Extracting free surface iso-surfaces should be exclusively used for fully photo-realistic renderings for internal or external marketing. In these situations, the best thing to use for iso-surfacing is the Shepard coefficient (via ParaView’s Contour filter). For fluids, the value that gives the most effective results is between 0.15 and 0.3, depending on the case.
Value of the Shepard coefficient for extracting a free surface is completely arbitrary. In other words, the values we recommend are only best practice advice as we have seen those numbers give the most realistic impression of the fluid in most cases.
For more instruction-based advice, please consult the training material.
