Elements are a fundamental part of any finite element analysis, since they completely represent (to an acceptable
approximation), the geometry and variation in displacement based on the deformation of the structure.
The different elastic material types provided by OptiStruct are: isotropic, orthotropic, and anisotropic materials. The material property definition cards are used to define
the properties for each of the materials used in a structural model.
High Performance Computing leverages computing power, in standalone or cluster form, with highly efficient software,
message passing interfaces, memory handling capabilities to allow solutions to improve scalability and minimize run
times.
Contact is an integral aspect of the analysis and optimization techniques that is utilized to understand, model, predict,
and optimize the behavior of physical structures and processes.
OptiStruct and AcuSolve are fully-integrated to perform a Direct Coupled Fluid-Structure Interaction (DC-FSI) Analysis based on a
partitioned staggered approach.
Uniaxial Fatigue Analysis, using S-N (stress-life) and E-N (strain-life) approaches for predicting the life (number
of loading cycles) of a structure under cyclical loading may be performed by using OptiStruct.
Multiaxial Fatigue Analysis, using S-N (stress-life), E-N (strain-life), and Dang Van Criterion (Factor
of Safety) approaches for predicting the life (number of loading cycles) of a structure under cyclical
Seam Weld Fatigue analysis is available to facilitate Fatigue analysis for seam welded structures. It allows you to
simulate the Fatigue failure at the seam weld joints to assess the corresponding fatigue failure characteristics like
Damage and Life.
OptiStruct provides industry-leading capabilities and solutions for Powertrain applications. This section aims to highlight OptiStruct features for various applications in the Powertrain industry. Each section consists of a short introduction, followed
by the typical Objectives in the field for the corresponding analysis type.
This section provides an overview of the capabilities of OptiStruct for the electronics industry. Example problems pertaining to the electronics industry are covered and common solution
sequences (analysis techniques) are demonstrated.
OptiStruct generates output depending on various default settings and options. Additionally,
the output variables are available in a variety of output
formats, ranging from ASCII (for example, PCH) to binary files (for example,
H3D).
A semi-automated design interpretation software, facilitating the recovery of a modified geometry resulting from a
structural optimization, for further use in the design process and FEA reanalysis.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides
you with examples of the real-world applications and capabilities of OptiStruct.
Surface condition is an extremely important factor influencing fatigue strength, as
fatigue failures nucleate at the surface. Surface finish and treatment factors are
considered to correct the fatigue analysis results.
Surface finish correction factor Cfinish is used to characterize the roughness of the
surface. It is presented on diagrams that categorize finish by means of qualitative
terms such as polished, machined or forged. 1
Figure 1. Surface Finish Correction Factor for Steels
Surface treatment can improve the fatigue strength of components. NITRIDED,
SHOT-PEENED, and COLD-ROLLED are considered for surface treatment correction. It is
also possible to input a value to specify the surface treatment factor Ctreat.
In general cases, the total correction factor is Csur=Ctreat⋅Cfinish
If treatment type is NITRIDED, then the total correction is Csur=2.0⋅Cfinish(Ctreat=2.0).
If treatment type is SHOT-PEENED or COLD-ROLLED, then the total correction is Csur = 1.0. It means you will ignore the effect of
surface finish.
The fatigue endurance limit FL will be modified by Csur as: FL'=FL*Csur. For two segment S-N curve, the stress at the
transition point is also modified by multiplying by Csur.
Surface conditions may be defined on a PFAT Bulk
Data Entry. Surface conditions are then associated with sections of the model
through the FATDEF Bulk Data Entry.
Fatigue Strength Reduction Factor
In addition to the factors mentioned above, there are various other factors that could affect the
fatigue strength of a structure, that is, notch effect, size effect, loading type.
Fatigue strength reduction factor Kf is introduced to account for the combined effect of
all such corrections. The fatigue endurance limit FL will be modified by Kf as: FL'=FL/Kf
The fatigue strength reduction factor may be defined on a
PFAT Bulk Data Entry. It may then be associated with
sections of the model through the FATDEF Bulk Data
Entry.
If both Csur and Kf are specified, the fatigue endurance limit FL will
be modified as: FL'=FL⋅Csur/Kf
Csur and Kf have similar influences on the E-N formula through
its elastic part as on the S-N formula. In the elastic part of the E-N formula, a
nominal fatigue endurance limit FL is calculated internally from the reversal limit
of endurance Nc. FL will be corrected if Csur and Kf are presented. The elastic part will be modified as
well with the updated nominal fatigue limit.
Scatter in Fatigue Material Data
The S-N and E-N curves (and other fatigue properties) of a material is obtained from
experiment; through fully reversed rotating bending tests. Due to the large amount
of scatter that usually accompanies test results, statistical characterization of
the data should also be provided (certainty of survival is used to modify the curves
according to the standard error of the curve and a higher reliability level requires
a larger certainty of survival).
Figure 2. S-N Curve with Scatter Data
To understand these parameters, let us consider the S-N curve as an example. When S-N
testing data is presented in a log-log plot of alternating nominal stress amplitude
Sa or range SR versus cycles to failure N, the relationship between S and N can be
described by straight line segments. Normally, a one or two segment idealization is
used.
Figure 3. One Segment S-N Curve in log-log Scale
Consider the situation where S-N scatter leads to variations in the possible S-N
curves for the same material and same sample specimen. Due to natural variations,
the results for full reversed rotating bending tests typically lead to variations in
data points for both Stress Range (S) and Life (N). Looking at the Log scale, there
will be variations in Log(S) and Log(N). Specifically, looking at the variation in
life for the same Stress Range applied, you may see a set of data points which look
like this.
S
2000.0
2000.0
2000.0
2000.0
2000.0
2000.0
Log (S)
3.3
3.3
3.3
3.3
3.3
3.3
Log (N)
3.9
3.7
3.75
3.79
3.87
3.9
As with many processes, the distribution of Log(N) is assumed to be a Normal
Distribution. The material data input on the
MATFAT entry is based on the mean of the scatter.
Figure 4. Probability Function of the Log(N) Distribution for S-N
Scatter
The experimental scatter exists in both Stress Range and Life data. On the
MATFAT entry, the Standard Deviation (or Standard Error) of the
scatter of log(N) is required as input (SE field for S-N curve).
Any normal distribution is fully defined by specifying the mean and its standard
deviation, in the case of S-N fatigue analysis in OptiStruct, the
mean is provided by the S-N curve as log(N50%i), whereas, the standard deviation is input via the
SE field of the
MATFAT entry.
If the specified S-N curve is directly utilized, without any perturbation, then the
mean values of the normal distributions at each data point is assumed to be used,
leading to a certainty of survival of 50%, by default. This is a consequence of S-N
material data that is available for the mean values of log(N). Since a value of 50%
survival certainty may not be sufficient for all applications, OptiStruct can internally perturb the S-N material data to the required
certainty of survival defined by you. To accomplish this, the following data is
required.
Standard Deviation (Standard Error) of log(N) normal distribution
(SEon
MATFAT).
Certainty of Survival required for this analysis (SURVCERT on FATPARM).
A normal distribution or gaussian distribution is a probability density function
which implies that the total area under the curve is always equal to 1.0. log(N)
values which are higher than the mean are always more conservative. Therefore, for
certainty of survival calculations, any value greater than 50% implies that the
log(N) values lower than the mean are being considered. The total area of the curve
starting from the right end of the Normal curve (which is typically positive
infinity for a PDF) is directly equal to the certainty of survival (or probability
of survival).
A typical normal distribution is characterized by the following Probability Density
Function:(1)
P(x)=1√2πσ2e−(x−μ)22σ2
Where,
x
The sample value (log(Ni)) for which the probability of occurrence
is calculated in a particular range (based on the specified certainty of
survival).
μ
The mean log(N50%i)
σ
The standard deviation (or standard error, given by
SE field on
MATFATin
the Assign Material dialog).
The area of the curve from the right end can be understood to be equal to the
certainty of survival specified on the SURVCERT field. This integral equation can be solved directly
to generate the value of x (or log(Ni)) which will allow a perturbation of the S-N curve.
However, the general practice is to convert the normal distribution function into a
standard normal distribution curve (which is a normal distribution with mean=0.0 and
standard error=1.0). This allows us to directly convert the certainty of survival
values into corresponding log(Ni)values (via Z-tables).
Note: The certainty of survival
is equal to the area of the curve under a probability density function between
the required sample points of interest. It is possible to calculate the area of
the normal distribution curve directly (without transformation to standard
normal curve), however, this is computationally intensive compared to a standard
lookup Z-table. Therefore, the generally utilized procedure is to first convert
the current normal distribution to a standard normal distribution and then use
Z-tables to parameterize the input survival certainty.
The equation used to convert the normal distribution to a standard normal
distribution is:(2)
z=x−μσ
This transformation leads to a corresponding standard normal distribution with a mean
of 0.0 and standard error of 1.0. Replacing the values with fatigue data, and
rewriting the equation.(3)
log(Ni)=log(N50%i)+z*SE
The value of z is procured from the standard normal distribution
Z-tables based on the input value of the certainty of survival (which is the area
under the curve from the right end of the curve up to the corresponding negative
Z-value). Some typical values of Z for the corresponding certainty of survival
values are:
Z-Values (Calculated)
Certainty of Survival (Input)
0.0
50.0
-0.5
69.0
-1.0
84.0
-1.5
93.0
-2.0
97.7
-3.0
99.9
Based on the above example (S-N), you can see how the S-N curve is modified to the
required certainty of survival and standard error input. This technique allows you
to handle Fatigue material data scatter using statistical methods and predict data
for the required survival probability values.
