CTAXI / CTRIAX6 Element Checks and Default Bound Values
3-node CTAXI / CTRIAX6 Element Check and Default Bounds
The element check and default bounds of the 3-node CTAXI or CTRIAX6 element are identical as those of the CTRIA3 element.
6-node CTAXI / CTRIAX6 Element Check and Default Bounds
The element check and default bounds of the 6-node CTAXI or CTRIAX6 element are identical as those of the CTRIA6 element.
