MODESELECT
Subcase Information Entry The MODESELECT command can be used in the I/O Options or the Subcase Information section to select a subset of computed modes in modal dynamic analysis subcases.
MODESELECT (type) = n
Mode selection based on arbitrary mode numbers.
Alternate Format 1
MODESELECT (type, LMODES = lm)
Mode selection based on lowest modes.
Alternate Format 2
MODESELECT (type, LMODENM = lom, HMODENM = him)
Mode selection based on a range of mode numbers.
Alternate Format 3
MODESELECT (type, LFREQ = lof, HFREQ = hif, UNCONSET = m)
Mode selection based on a range of frequencies.
Argument | Options | Description |
type | <STRUCTURE, FLUID> |
n | n > 0,
n < 0 (Integer) |
LMODES | lm (Integer > 0) |
Specifies the number of lowest modes to be selected. |
LMODENM | lom (Integer > 0) |
Specifies the lower bound of the mode number range for selecting modes. 3 |
HMODENM | him (Integer > lom > 0) |
Specifies the upper bound of the mode number range for selecting modes. 3 |
LFREQ | lof (Real ≥ 0.0) |
Specifies the lower bound of the frequency range for selecting modes. 4 |
HFREQ | hif (Real > lof ≥ 0.0) |
Specifies the upper bound of the frequency range for selecting modes. 4 |
UNCONSET | UNCONSET | This flag indicates that the following fields specify a single mode or a set of modes for unconditional inclusion or exclusion. |
m | m > 0,
m < 0 (Integer) |
- The MODESELECT I/O Options Entry is only supported in modal frequency response, modal transient and complex eigenvalue analyses. It is not supported in Response Spectrum Analysis.
- Multiple MODESELECT entries are allowed in a model. MODESELECT entries can be specified above the first subcase or within each subcase.
- If LMODENM is specified
without HMODENM, a default value of 10000000 (ten million) is
assumed for HMODENM. If HMODENM is specified
without LMODENM, a default value of 1 is assumed for
LMODENM.
Defaults LMODENM HMODENM specified 1.0E+7 1 specified - If LFREQ is specified without
HFREQ, a default value of 1.0E+30 is assumed for
HFREQ. If HFREQ is specified without
LFREQ, a default value of 0.0 is assumed for
LFREQ.
Defaults LFREQ HFREQ specified 1.0E+30 0.0 specified - When the MODESELECT Case Control command is used in conjunction with the parameter LFREQ, the MODESELECT Case Control takes precedence.
- If the use of MODESELECT results in all or none of the computed modes for use, you are informed with a message.
- The faster method for modal frequency response analysis (activated by PARAM,FASTFR,YES) cannot be used in conjunction with MODESELECT.
- Modes that are eliminated by MODESELECT will display an "S" next to the mode number, if the mode is eliminated by MODESELECT in one subcase and PARAM, LFREQ or PARAM, HFREQ in another subcase, or an "M" next to the mode number, if eliminated by MODESELECT in at least one subcase.
