/ATFILE
Engine Keyword Defines the frequency of writing additional time history file of T-file "RunnameTnnx".
/ATFILE/Type
Δ T h i s MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads fadaWgaaWcbaGaamiAaiaadMgacaWGZbaabeaaaaa@3AE8@
Data Description SI Unit Example
Type Output format.
No value
Built in format of current Radioss version
= 1
Binary (not readable by most Radioss post-processors)
= 2
Coded ASCII 32-bit
= 3
ASCII
= 4 (Default)
Binary IEEE 32-bit
Δ T h i s MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeiLdiaads fadaWgaaWcbaGaamiAaiaadMgacaWGZbaabeaaaaa@3AE8@ Time frequency to write data on history plot file T-file.
  1. This option is used to define the frequency of writing additional time history files named RunnameTnnx (Tnna, Tnnb, Tnnc ...). The contents of these files are defined through the option /xTH (where x= A to I). These options use the same keyword format and variables as Time Histories, except for the addition of the prefix (/ATH, /BTH...). The frequency of output for the additional time history files is defined using /xTHFILE (where x = A to I).
  2. Recommended options are default (no value) or four, which can be read by HyperGraph.
  3. See File Extensions and Formats for details of T-file name.
