Loading [MathJax]/jax/output/CommonHTML/jax.js
Composite Properties
Composite could be modeled with solid or shell element. Depending on the element type, the following properties can be used in Radioss to model a composite.
Shell Elements
Modeling composite in Radioss could be defined by Layer based or Ply based with different property.
  • Layer based modeling with /PROP/TYPE10 (SH_COMP), /PROP/TYPE11 (SH_SANDW)
  • Ply based modeling with /PROP/TYPE17 (STACK), /PROP/TYPE51, /PROP/PCOMPP+/STACK, /PROP/TYPE19 (PLY) and /PLY
For ply-based modeling, info (like material, thickness, anisotropic angle, anisotropic axis angle and number of integration points) for each ply defined in /PROP/TYPE19 (or /PLY) and assembled in /PROP/TYPE17 or /PROP/TYPE51 (or /STACK) with option Pply_IDi.
For ply-based modeling, the way of assemble plies could be “by ply” or “by substack”. “By ply” is simply pile up plies one by one from bottom to top. The way “by substack” need first pile up plies one by one to create each substack, and then each substack could either be combined or could also be stacked with substack connection “INT”.
Figure 3.
Figure 4. Stack in /PROP/TYPE51
For composite property following topics are:
  • Layer (ply) number and integration points each layer (ply)
  • Anisotropy in layer (ply)
  • Layer (ply) thickness and position
  • Composite material used for Layer (ply)
      Layer-based Properties
    /PROP/TYPE10 (SH_COMP) /PROP/TYPE11 (SH_SANDW)
    N
    Layer Numbers
    Or Pply_IDi
    Ply Numbers
    N=0~100 N=1~100
    IP of each layer/ply 1 per Layer 1 per Layer
    Iint
    Integration formulation
    ϕi+V
    Anisotropic direction
    ϕi+ skew
    θdrape
    Ply orientation change
    αi
    Angle between anisotropic axis
    ti
    Layer/Ply thickness
    Ipos + Zi
    Layer/Ply position
    Ipos=2,3,4
    Layer/Ply offset
    mat_IDi
    Material for each layer/ply
    Use material defined in /PART
    Must use same material type for all layers.
    Commonly used Composite Material Law 15, 25 and user material 15, 25 and user material
    XFEM compatibility (crack propagation)
    With /FAIL/JOHNSON, /FAIL/TAB1 and /FAIL/TBUTCHER
    Plyxfem
    Delamination between layer/ply
    Minterply
    Material between layer/ply
      Ply-based Properties
    /PROP/TYPE17 + /PROP/TYPE19 /PROP/TYPE51 + /PROP/TYPE19 /PROP/PCOMPP+/STACK+/PLY
    N
    Layer Numbers
    Or Pply_IDi
    Ply Numbers
    Pply_IDi=1~200 Pply_IDi=1~200 Pply_IDii1~n
    IP of each layer/ply 1 per Ply
    Npt_ply=1 in /PROP/TYPE19
    1~9 per Ply
    Npt_ply=1~9 in /PROP/TYPE19
    1~9 per Ply
    Npt_ply=1~9 in /PLY
    Iint
    Uniformed or Gauss
    Uniformed or Gauss
    ϕi+V
    ϕi+ skew
    θdrape
    Defined in /PROP/TYPE19
    Defined in /PLY
    αi
    in /PROP/TYPE19
    in /PROP/TYPE19
    in /PLY
    ti
    Layer/Ply thickness
    Different in /PROP/TYPE19
    Different in /PLY
    Ipos + Zi
    Layer/Ply position
    Ipos=2,3,4
    Layer/Ply offset
    mat_IDi
    Must use same material type for all plies.
    Different material type allows for each ply.
    Commonly used Composite Material Law 25, 27, 36, 60, 72, 93 and user material 25, ≥28 and user material 25 and user material
    With /FAIL/JOHNSON and /FAIL/TBUTCHER
    Plyxfem
    Minterply
    Only with LAW1+/FAIL/LAD_DAM
Layer (Ply) Number N (Nply_IDi) and Integration Points each Layer (Ply)
For layer-based modeling which use /PROP/TYPE10, /TYPE11. N is the number of layers through the shell thickness. For these properties, there is one integration point (IP) each layer.
For ply-based modeling, which use /PROP/TYPE17, /TYPE51 and /PCOMPP. Pply_IDi is the number of plies through the shell thickness. Plies could be combined until n plies for these properties.
For TYPE17 only one integration point is allowed while for TYPE51 and /STACKF until 9 integration points are allowed. Number of integration point defined with option “Npt_ply” in property TYPE19 or /PLY.
Example (Ply) (/PROP/TYPE51)
In this example, Npt_ply=3 defined in /PROP/TYPE19, means 3 integration points defined per ply and with option Iint=0 defined in /PROP/TYPE51, then these 3 integration points are uniformly distributed through each ply thickness.
Figure 5.
If Iint=1 in /PROP/TYPE51, then integration points are distributed follow Forces and Moments Calculation Gauss Integration Scheme through each ply thickness.
Figure 6.
It is possible to print animation results (plastic strain, damage, stress and strain tensor) in each specific integration point with /ANIM/SHELL/IDPLY/Keyword4/I/J (or /ANIM/SHELL/Keyword3/N/NIP).
For instance, use /ANIM/SHELL/IDPLY/EPSP/2/3 (or /ANIM/SHELL/EPSP/2/3) to print plastic strain in third integration point (red highlighted integration point in Figure 6) of second ply (ply name Ply12). For additional print info about Integration points through shell thickness for composite properties, refer to How is the generalized stress tensor /ANIM/SHELL/TENS/MEMB and /ANIM/SHELL/TENS/BEND computed? in the FAQs.
Anisotrophy in Layer (Ply)
  • The first anisotropic direction of material could be defined with angle ϕ and gloval vector V(VX,VY,VZ). It is also possible to use angle ϕ and skew. In this case, x-axis of skew replaced the global vector V.
    Project the global vector V in shell element and then rotate ϕ degree is the first anisotropic direction (also called Material direction 1). The positive direction of ϕ is coding to shell normal n. For example, in Figure 7 rotate counterclockwise ϕ degree is material direction 1.
    The material direction 1 of the local element reference is normally the fiber direction. Then the material character (E-Module, yield stress, and so on) of direction 1 which defined in material law could be then applied in the correct direction on local element reference.
    Figure 7.
  • Composite material could be orthotropic or anisotropic. In Radioss it is possible to describe this character with anisotropic axis angle αi in ply-based properties. In case of αi=90, then it describes orthotropic material. For layer based properties (TYPE10 and TYPE11) which without this option αi, so that only orthotropic material could be defined.
    Figure 8.
    Figure 9 shows an Example in /PROP/TYPE11 which use skew to define global vector V.
    Figure 9.
    For property TYPE11 and TYPE51, the anisotropic direction for some shell could also be initialized with ϕ in keyword /INISHE/ORTH_LOC or /INISH3/ORTH_LOC. For property TYPE51, anisotropic axis angle could also be initialized with these keywords.
  • The orientation of anisotropy for specific shell elements or shell element groups could be change again with option drape_ID and def_orth in /PROP/TYPE19 and /PLY. drape_ID defined in /DRAPE. With this feature, angle of anisotropic direction could be changed with θdrape.
    • If use def_orth=1:
      Angle ϕi, skew or global vector V will be ignored. Take shell local x-axis as vector V' and then rotate ϕ degree is the first anisotropic direction. ϕs (defined in /SHELL or /SH3N) is taken into account by compute angle ϕ.(1) ϕ=ϕs+Δϕ+θdrape
    • If use def_orth=2 (Default)
      Project the global vector V in shell element to vector V' and then rotate ϕ degree is the first anisotropic direction. The angle ϕ is computed as:(2) ϕ=ϕi+Δϕ+θdrape
      Figure 10.
Layer (Ply) Thickness and Position
  • For /PROP/TYPE10, layer thickness is simply averaged by layer number(3) ti=Thick/N
    and layers are automatically overlying one by one from bottom to top.
    Figure 11.
  • For property TYPE11, TYPE17, TYPE51 and /STACK, layer (ply) position and thickness depend on option Ipos
    • If Ipos=0
      User layer (ply) thickness input ti will be taken, and layer (ply) position will be automatically overlying one by one from bottom till top; but if,(4) itiThick
      Then, layer (ply) thickness will be adjusted to tnewi, so that(5) itnewi=Thick
      Layer (ply) position will be then adjusted, as well.
    • If Ipos=1
      User layer(ply) input of thickness ti and position Zi will be taken. Sum of layer thickness will not be checked with Thick.
      For additional information, refer to How does Radioss calculate layer thickness and layer position in /PROP/TYPE11 and /PROP/TYPE16? in the FAQs.
  • For property TYPE17, TYPE51 and /STACK, it is also possible to offset the plies with Ipos=2, 3, 4
    • Ipos=2: the shell element mid-surface is at Z0 from the bottom of the ply layout
      Figure 12.
    • Ipos=3: the top of the ply layout is coincident with the element mid-surface
      Figure 13.
    • Ipos=4: the bottom of the ply layout is coincident with the element mid-surface
      Figure 14.
  • For /PROP/TYPE17, /PROP/TYPE51 and /STACK, ply thickness could be changed by option Thinning in /DRAPE (which is used in /PROP/TYPE19 or /PLY). Then updated ply thickness is: (6) tnewi=tiThinning
Composite Material Used for Layer (Ply)
Composite material LAW15 and LAW25 could be used for shell element. Failure model /FAIL/HASHIN, /FAIL/PUCK and /FAIL/LAD_DAMA with LAW25 and /FAIL/CHANG with LAW15 could be used to describe composite behavior for shell element. For additional information, refer to Composite Material.
  • Material for layer (ply)
    • For property TYPE10, composite used material defined in /PART
    • For property TYPE11 and TYPE17, composite used material defined in option mat_IDi. Different material ID could be defined for each layer (ply). But they must use same material type. If using LAW25, then several different LAW25 cards can be used for different layer (ply).
    • For property TYPE51 and /STACK, composite also used material defined in option mat_IDi and different material type or ID could be used for each ply.
  • Material between ply
    For property TYPE17, it is possible to define delamination between plies or stacks (with Plyxfem=2). This is very useful for delamination is the main driven of composite failure. The material between plies defined with Minterply. For the moment, LAW1+/FAIL/LAD_DAM could be used to describe three different type of ply delamination.
    Figure 15.
    And then in this case additional variable δ1,δ2,δ3 are added on each node of ply by computation to simulate the delamination failure between plies.
    Figure 16.
Solid Element
The new composite technology allows you to make parts production more and thicker, as modeling those parts with shell elements is not enough. Thick shell can solve this problem. Compare with shell element, thick shell could direct connect with other solid part.
For Solid element, for the moment only layer-based modeling with property /PROP/TYPE22 (TSH_COMP) is available. This solid property is similar to shell property /PROP/TYPE11 by define composite.
Layer Numbers Isolid=14:
Iint=9~200
Isolid=15:
IP of each layer/ply Inpts=ijk=2~9 Inpts=j=1~200
ϕi + V, Anisotropic direction
ϕi + skew, Anisotropic direction
θdrape, Ply orientation change
αi, Angle between anisotropic axis
ti, Layer/Ply thickness
defined with factor ti/t
Ipos + Zi, Layer/Ply position
Ipos=2,3,4, Layer/Ply offset
mat_IDi, Material for each layer/ply
Different material type allows for each layer.
Commonly used Composite Material LAW LAW12, LAW14, LAW25 and user material
Plyxfem, Delamination between layer/ply
Minterply, Material between layer/ply
Similar to shell property /PROP/TYPE11, reference vector V and angle ϕ are used to define the material direction 1. The reference vector V project to the middle surface of solid element and turn ϕ degree is the material direction 1.
Figure 17.
Layer Thickness and Position
For solid element thickness and position defined by element mesh.
  • With option mat_IDi, it is possible to use different material type for each layer
  • Composite material LAW12, LAW14 and LAW25 could be used with this property
  • Failure model /FAIL/HASHIN, /FAIL/PUCK and /FAIL/LAD_DAMA with these composite material laws are also accounted for
  • Material referred to in the corresponding /PART card is only used for time step and interface stiffness calculation
  • For LAW25, it is assumed that (for solids and thick shells) the material is elastic in transverse direction (material direction 2 and 3) and the E33 value must be specified in such cases
For additional information, refer to “Composite material and Composite failure”.
1
L. Gornet, “Finite Element Damage Prediction of Composite Structures"
