/ANIM/SHELL/IDPLY/EPSP
Engine Keyword Generates animation files containing plastic strain for shell elements that use ply-based composite properties, /PROP/STACK (TYPE17), /PROP/TYPE51, or /PCOMPP.
/ANIM/SHELL/IDPLY/EPSP/Keyword5/Keyword6
Data Description SI Unit Example
Keyword5 Ply output:
I
Ply ID number
Integration point Keyword6 must also be entered.
ALL
All the integration point results of all the plies are output.
Keyword6 Output location. Only used if Keyword5 is entered.
J
j’th integration point of the Ply I
  1. Ply ID number is prop_ID from /PROP/TYPE19 (PLY)/prop_ID or ply_ID from /PLY/ply_ID.
  2. For fully integrated BATOZ shells, Ishell=12, the output value is the average of the in-plane Gauss points.
