Engine Keyword Describes the message level for BCS (Boeing)
solver.
/IMPL/SBCS/MSGLV/n
Data |
Description |
SI Unit Example |
n |
- = 0 (Default)
- No printed messages, except the primary messages
generated by standard error handler.
- = 1
- Produces a small amount of runtime statistics and any
detailed error messages.
- = 2
- Creates a more complete set of runtime statistics and a
log of steps in the process.
- = 3
- Produces diagnostic output, including output of the
content of various arrays whose length is no larger than
the number of equations.
- ≥ 4
- Will produce volumes of output for debugging
purposes.
- A setting greater than 2,
produces debugging output and is not recommended for general use.
