Processing math: 100%
/LOAD/CENTRI
Block Format Keyword Apply a centrifugal force on a set of nodes according a body rotational velocity around the defined direction.
/LOAD/CENTRI/load_ID/unit_ID
load_title
fct_IDT Dir frame_ID sens_ID grnod_ID Ivar Ascalex Fscaley
load_ID Load identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
load_title Load title
fct_IDT Time function identifier, giving the rotational velocity ω versus time.
(Integer)
Dir Direction of rotation (input XX, YY or ZZ)
(Text)
frame_ID Frame identifier
= 0
Rotation is expressed in global reference system
0
Rotation is expressed with respect to the frame.
(Integer)
sens_ID Sensor identifier.
(Integer)
grnod_ID Node group to which the load is applied.
(Integer)
Ivar Flag to disregard variation of velocity with respect to time, for the calculation of the force.
= 1 (Default)
Variation of velocity is not taken into account.
= 2
Variation of velocity is taken into account.
(Integer)
Ascalex Abscissa scale factor.
Default = 1.0 (Real)
[s]
Fscaley Ordinate scale factor.
[N]
  1. A force is computed corresponding to a body rotational velocity around the direction Dir of the global reference system if frame_ID = 0, or the reference system defined by the frame if frame_ID ≠ 0.
  2. This option is not a kinematic condition (velocity of the nodes is not specified).
  3. If frame_ID = 0, the force applied to the node of mass m , at location M is computed as:(1)
    F=m(dωdtOM+ωωOM)
    If Ivar = 1:
    dωdtOM is not taken into account.(2)
    F=m(ωωOM)
  4. If frame_ID0, the force applied to a node is computed as: (3)
    F=fr+fe+fc
    Driving force:(4)
    fe=m(γ(A)+(dΩ(R'/R)dt)AM+Ω(R'/R)(Ω(R'/R)AM))
    Coriolis force:(5)
    fc=m(2Ω(R'/R)v(M)/R')
    Relative force:(6)
    fr=m(dωdtAM+ωωAM)
    If Ivar = 1:
    dωdtAM is not taken into account in relative force.
    (7)
    fr=m(ωωAM)
    Where,
    R
    Global reference system
    R'
    Reference system defined by the frame
    A
    Origin of the frame
    M
    A point of the defined group of node
    Ω(R'/R)
    Rotational velocity of the frame with respect to the global reference system
    ω
    Rotational velocity defined by the time function
