Write a C/C++ OML Library Using the Binary-compatible Interface
The benefit of using this interface is that the objects are size invariant. This means that the code you compile can be used with any version of Compose that supports this interface (2017.2 or later), not just the version that the header file came from. The interface allows you to compile with tools different than what the Compose executable uses.
- An initialization function that is called by Compose. This is how your library's functions get registered with Compose.
- The functions themselves.
int InitToolbox(OMLInterface* eval)
This function must be declared as extern “C” so that the name is not mangled by the compiler. It must also be exported from the DLL.
The methods of the OMLInterface class are documented in Methods for the C/C++ OML Libraries.
eval->RegisterFunction(“myfunc”, myfunc);
// myfunc needs to be forward declared
eval->RegisterFunction(“myfunc2”, myfunc2);
return 0;
bool myfunc(OMLInterface* eval, const OMLCurrencyList* inputs, OMLCurrencyList* outputs)
Since OML is an untyped language, it is up to the writer to determine the proper C++ type for each input and handle it accordingly.
The OMLCurrencyList class and all of its subordinate classes are also documented in the Methods for the C/C++ OML Libraries section.
// check proper number of inputs
if (inputs->Size() != 2)
eval->ThrowError(“Incorrect number of inputs”);
OMLCurrency* input1 = inputs->Get(0);
OMLCurrency* input2 = inputs->Get(1);
// check proper input types
if (input1->IsScalar() && input2->IsScalar())
double d1 = input1->GetScalar();
double d2 = input2->GetScalar();
outputs->AddScalar(d1+d2);
else
eval->ThrowError(“Invalid input type”);
return true;
